It is currently Tue Nov 24, 2026 2:42 am
 Post subject: Quick carb question
PostPosted: Sat Dec 13, 2008 8:40 am
On the idle mix screws, does turning them out make it leaner or richer? I had always thought in was richer and out was leaner, but I had a guy on another Mopar site tell me it was the opposite. So which is it?
Rob M
'80 D100 SWB stepside, S6 4-spd OD
PostPosted: Sat Dec 13, 2008 8:51 am
On our stock carbs for the SL6 out means richer fuel mix.
PostPosted: Sat Dec 13, 2008 8:55 am
If you take the screw out, you'll see that the end of the screw is shaped like a cone. The end fits into a cone shaped recess, so the further in it is screwed, the more it restricts the fuel flow.
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Sat Dec 13, 2008 11:15 am
There have been a few carburetors (certain Holley 4-barrels, if I remember correctly) that have reverse idle mixture screws that control air rather than fuel flow. But most carbs, including all slant-6 items, are clockwise to lean and anticlockwise to richen.
PostPosted: Sun Dec 14, 2008 12:19 pm
Okay, thanks guys.
Rob M
PostPosted: Sun Dec 14, 2008 1:31 pm
Also certain Holley 2300 2 barrel carbs also were reverse idle screw models that were for OEM replacement on Ford Engines. A couple ways to tell for the Holley is either 1) if 'new' it will use a plastic cover over the idle screws to keep them 'calibrated', 2) you can pull the screw out of the metering block the tip of the 'needle' on the screw is dull and rounded, whereas the regular idle versions have a sharp 'point' to them.
A while back I had installed a Holley 2300 0-80179, that was reverse idle screws and used the economaster venturies, if this was easily convertabile to a standard metering block, it would have been a good 'street' carb, the reverse idle screws just didn't have the 'window' of tuneability to keep things 'right' for the 225.
-d.Idiot
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
