It is currently Fri Jun 05, 2026 10:01 pm
 Post subject: 1975 dodge info needed
PostPosted: Tue Dec 16, 2008 9:05 pm
I just picked up a 1975 dodge dart custom 4dr to day!! With a six. I need some help in finding out some more info on the car I have a vin# LH41C5B344991 and the tag in the motor bay is
L2 611
M25 M26 M38 N37 R11
J52 K5X L31 L73 M15 M21
V1Y U 1 B43 C15 G25 G52
LY6 L1Y3 KY4 722 170092
E24 D34 LH41 C5B 344991
It's in real good shape it will need a carb clean or a new carb, would only run on gas that was pored into the carb, I went out and bought everything to get it running, the weather is bad out this way so I will have to get it next week. We have 6in of snow right now and it is still comming down.
I wish that this thing was a Plymouth. I had one while going to school, a 1974 Plymouth custom 4dr in avocado green with a white top. So this car will bring back many memorys for me. Oh the car has 38,005 original miles on it the insides look like new and there is no to very little rust on the out side of it. I will need some better bumpers for it though, they are getting kind of bad, it has been sitting for 5-6 years with very little on the running end. any help with what I have just put $550.00 on would be help full. I will let you all know how this one go's. I have a 1953 Plymouth that I have driven so this will be kind of nice next to that in the drive!!
1930 Jordan Great Line "90", 1951 Chrysler Saratoga,1953 Plymouth, 1971 Honda CB 500 "4", 1973 Honda CB 350, 1975 Honda CB 500 twin, 1988 Honda Shadow 1340, 1975 Dodge Dart Custom, 1992 Dodge 2500 turbo truck,1975 Schwinn Collgate 5sp.
PostPosted: Tue Dec 16, 2008 9:48 pm
E24: 225 1-barrel 6-cyllinder engine
D34: TorqueFlite 3-speed automatic transmission
L: Dodge Dart / Demon family
H: High trim/price class
41: 4 Door Sedan
C: 225 105HP(net) 6-cylinder engine, single 1bbl carb
5: 1975 model year
B: Built at Dodge Main plant, Hamtramck, MI, USA
344991: Vehicle serial number
LY6: Main body paint code, Inca Gold Poly (metallic), PPG #2738
L: Low price/grade interior trim
1: Cloth and vinyl bench seats
Y3: Light gold interior colour
KY4: Upper door frame paint: Golden Fawn, PPG #2635
722: Built on July 22, 1975
170092: Vehicle order number
V1Y: Full vinyl roof, gold colour
U1: Built to U.S. market specifications (probably California specs — is this a California car?)
B43: Nonpower Brakes
C15: "Quiet car" sound insulation pkg
G25: Manual vent windows
G52: Chrome left sideview mirror, remote control
J52: Inside hood release
K5X: Bodyside mouldings, protective w/black vinyl insert
L31: Fendertop turn signal indicators
L73: Fasten Seatbelts reminder light
M15: Upper door frame mouldings, stainless steel
M21: Roof drip rail mouldings, stainless steel
M25: Wide sill mouldings
M26: Wheel lip mouldings
M38: Deck lid finish panel mouldings
N37: Catalytic converter w/unleaded fuel pkg (again, probably a California car)
R11: Music Master radio, AM
Not sure what to do with the L2 or 611. Welcome on the board! You'll want a factory service manual. Tune-up parts and technique suggestions in this thread. Remember this engine needs periodic valve adjustment. I may have a brand-new carburetor for you; don't buy "remanufactured" garbage from a parts store. For now, make sure to run the distributor vacuum advance hose directly from the carburetor to the distributor, not stopping at the widget (OSAC) on the air cleaner.
PostPosted: Wed Dec 17, 2008 3:12 pm
I don't know if this is a californian car due to it is from IL area. It was sold out this way(IL) and I will be the 2nd owner. I will get back to you on the carb thanks for the offer on that. Also thanks for the info on the car!! I just love it. I will have more info for you next week when I get it Home and go throughout it. Thanks for all the help so far.
PostPosted: Thu Dec 18, 2008 2:29 am
Can I use a 1920 Holly on this car?? I have 2 of these in the garage. Also if they will not work what would you need for that carb, if you have one that would work for me?? Thanks, Rob
PostPosted: Thu Dec 18, 2008 9:20 am
Some variants of the 1920 could be adapted without much difficulty to your '75. It would be easiest with a '73 1920, which would have just about all the hookups present on your original 1945 carburetor. '71-'72 1920s would lack the venturi vacuum tap to run the EGR system, and there is no workaround or substitute, so you'd need to disable the EGR altogether if you use a pre-1973 carburetor.
Carburetors and catalytic converters never got along well, particularly before the 1981 introduction of feedback carburetors (which have their own big problems). If your 1975 is not subject to emission tests where it is registered, you would do well to delete the catalyst (if the car is still so equipped).
You may want to peruse this thread for a rundown on the various emission control systems before you make a decision on what carb to use.
Whichever carb you pick, it needs to be in good condition or you'll have poor driveability and fuel economy.
PostPosted: Thu Dec 18, 2008 11:47 pm
Thanks for that info on the carb, I think that if I just clean this one up it will be ok I hope. Also when I go to get the car the battery is from 2001 and I don't think it's ok. So could I use one of the batterys from my truck wich is a BIG one and I think they each have 850 cold cranking amps or would I fry the alt on the dart?? I am hopping I could use a truck bat for now due to I am not driving it in the winter any more. The diesel is no good for me any more in the winter. Rob
PostPosted: Fri Dec 19, 2008 9:19 am
There's no way a "big" battery could fry anything in your car, as long as it is hooked up correctly and not backwards.
As quickly as you can, get these three books and read them cover to cover.
