It is currently Mon Jun 15, 2026 10:28 am
 Post subject: Radiator Question
PostPosted: Sat Jan 03, 2009 6:38 pm
I'm getting a lot of water leakage from the radiator. I'm having to fill it up with water about once a week. After driving for a few miles, theres a noticeable leak near the top of the radiator coming from both sides. Whats the better solution, to take it to a radiator shop to get rebuilt or to just buy a new one? I'm not sure if "new" radiators are just the remanufactured crap like the starters and alternators are. I don't really know anything about radiators so I figured I'd learn about it by asking here first. Thanks.
PostPosted: Sat Jan 03, 2009 7:09 pm
How are you with a propane torch?
If it's just the top tank, it should be easy to resolder......
PostPosted: Sat Jan 03, 2009 10:05 pm
Or take it to a rad shop,get it boiled,rodded and rebuilt.New rads are new but no telling which chinese province it will come from.
PostPosted: Sat Jan 03, 2009 10:25 pm
I would keep it and have it cleaned and sealed up at a good quality shop that stands behind their work. That way if it should spring a leak in the repair area, they will fix it for free. Been there done that in regards to tank leaks. If the core is bad, then that's another matter. You can have an new core assembled with your parts.
Another option is eBay had some new OEM radiators that were found about a month ago. They may still have some left. They were about $100.
PostPosted: Sun Jan 04, 2009 7:19 am
Fix vs. replace depends on what kind of condition your radiator's in. If it's just got a couple small leaks and is in otherwise good condition, repair makes sense. But if it's got a bunch of leaks and the core's clogged up and corroded, you may as well replace it. You can still buy a good quality new radiator for your car. Spectra Premium # CU354 if you want the standard 19"-wide radiator, or CU527 if you want the heavy duty 22"-wide item. Either should cost just shy of $200.
Or there is always this solution!
PostPosted: Sun Jan 04, 2009 8:39 am
I asked my long term Radiator guy about going over my Dart's radiator. He asked me if there was any white stuff showing on the core, answer was yes, a little at the bottom.
He than said; I can probably fix it, BUT, experience has shown that it is has due to its age now turned into Swiss Cheese, corroding from the inside out. If I clean it out, most likely more weak spots will present sooner or later, and the fix won't last. Best bet would be to replace it. I did not inquire about a recore, as this is a later on in the spring project.
PostPosted: Sun Jan 04, 2009 11:25 am
I chased a lot of leaks trying to keep my original radiator, and later another '64 radiator. It wasn't just the cores, either. The top tanks were rotting away and cracking.
Getting a new one solved the problems.
PostPosted: Tue Jan 06, 2009 9:09 pm
Looks like theres a little rust on both sides on the top where it's leaking, so I'm going to resolder it this Saturday. If that doesn't hold up long enough I'll just buy a new one. I called a couple radiator shops and they both told me $300-400 for a rebuild. Thats insane. I could buy one of those fancy aluminum ones Dan was talking about for that :lol:
