It is currently Wed Oct 14, 2026 4:44 am
 Post subject: 904 trans filter
PostPosted: Sat Mar 02, 2002 8:05 am
I have a 63 signet 200 225 AT. About a year ago I changed the fluid and filter and I am a little worried about having the newer filter in. Can this kill it? I don't drive a lot of miles. I also have a leak at the rear of the unit. Last weekend it was slow to go into gear, the level was low by a pint and that cleared it up I think. Should I put the old screen filter back in to be safe? The tranny has always worked fine,the fluid I did take out was dirty. Thanks!
Foxden@aug.com
PostPosted: Sat Mar 02, 2002 9:29 am
If the filter used is called-out for the 60-65 "early" 904 (cable type with two internal pumps) then you should be fine. These early filters have two feed holes going into the valve body.
If you installed a later filter, (only one feed hole) I would change it or at lease punch an extra hole to let fluid pass to the rear pump.
: I have a 63 signet 200 225 AT. About a year ago
: I changed the fluid and filter and I am a
: little worried about having the newer filter
: in. Can this kill it? I don't drive a lot of
: miles. I also have a leak at the rear of the
: unit. Last weekend it was slow to go into
: gear, the level was low by a pint and that
: cleared it up I think. Should I put the old
: screen filter back in to be safe? The tranny
: has always worked fine,the fluid I did take
: out was dirty. Thanks!
