| 904 trans filter https://slantsix.org/forum/viewtopic.php?t=3316 |
| Author: | KFox [ Sat Mar 02, 2002 8:05 am ] |
| Post subject: | 904 trans filter |
I have a 63 signet 200 225 AT. About a year ago I changed the fluid and filter and I am a little worried about having the newer filter in. Can this kill it? I don't drive a lot of miles. I also have a leak at the rear of the unit. Last weekend it was slow to go into gear, the level was low by a pint and that cleared it up I think. Should I put the old screen filter back in to be safe? The tranny has always worked fine,the fluid I did take out was dirty. Thanks! Foxden@aug.com |
| Author: | Doctor Dodge (Doug Dutra) [ Sat Mar 02, 2002 9:29 am ] |
| Post subject: | Re: "Special" 904 trans filter |
If the filter used is called-out for the 60-65 "early" 904 (cable type with two internal pumps) then you should be fine. These early filters have two feed holes going into the valve body. If you installed a later filter, (only one feed hole) I would change it or at lease punch an extra hole to let fluid pass to the rear pump. DD Quote:
: I have a 63 signet 200 225 AT. About a year ago : I changed the fluid and filter and I am a : little worried about having the newer filter : in. Can this kill it? I don't drive a lot of : miles. I also have a leak at the rear of the : unit. Last weekend it was slow to go into : gear, the level was low by a pint and that : cleared it up I think. Should I put the old : screen filter back in to be safe? The tranny : has always worked fine,the fluid I did take : out was dirty. Thanks! |
