It is currently Thu May 28, 2026 12:48 pm
 Post subject: Guzzi engine needs HELP
PostPosted: Tue Jan 13, 2009 4:55 pm
After tearing down the Guzzi car engine,number six rod and crank were pretty bad,had crank reground 20 under,Doc sent me a rod,,,,had my machine shop try to remove piston and it broke...So I am in need of a single, used .030 over piston,really want the same type,,"Badger 200" is whats cast on it,good used is fine,really want to make Vegas.any help is very appreciated,mark
PostPosted: Wed Jan 14, 2009 9:23 am
Wow... over 100 views and no-one has a "bucket-full" of good used .030 cast pistons?? :? :wink:
I will take a look, I think I have some.
PostPosted: Wed Jan 14, 2009 11:01 am
I guess I have some used ones on rods from my blown Project V motor. Thought he wanted new ones.
Let me know, Mark. I can send you a good rod/piston for shipping costs. Not guaranteed over 5500 RPM...
 Post subject: Pistons
PostPosted: Wed Jan 14, 2009 11:19 am
I have a set of 6 with rings and pins.Came out of my block . they were new and never had been run.I'm not sure of the brand(never really looked).Send me a PM if these would help you out. :)
SOOOOO much money spent and I keep gettin' told that I could have had a V-8
PostPosted: Wed Jan 14, 2009 6:42 pm
Really only need one good used Badger piston,to make this happen in time,dont really want to mix brands and weights,If nothing comes up in the next day or two,I will,,,cant figure out how to finish this sentence,,,,maybe figure something else out,Mark
PostPosted: Wed Jan 14, 2009 8:59 pm
Also have a set of springs comming from engine builder and 1 exhaust valve,1 got bent on number three,very small kiss on top of piston,so actually 2 pistons is what I really want.or six new 40,or 60 over and start all over,or start with fresh block and build a NEW engine around my 45 wiseco pistons and k1 rods,Vegas does not look like it will happen for me,mark
PostPosted: Thu Jan 15, 2009 6:24 am
Can't you buy a new Badger piston? Can't be more than $30, and more like $15 ea.
PostPosted: Thu Jan 15, 2009 9:51 am
I have some used .030 cast pistons but they are not Badgers.
Weigh one of your current assemblies and give me that number.
(piston, rod with cap, bolts/nuts but no rings)
If the weight is close... I will send you a few.
Just "patch" this engine together... save your big effort for the K1 motor.
PostPosted: Thu Jan 15, 2009 2:49 pm
Found a new Badger $17,four phone calls,thanks for all the offers,mark
