It is currently Wed Nov 11, 2026 11:20 pm
PostPosted: Thu Jan 15, 2009 7:25 am
Car Model: 1964 Valiant V200
My valiant was converted to electronic volt regulator with the standard Mopar A-circuit stuff many years ago, but I was thinking of converting it back to B-circuit regulation with the Echlin VR1001 or similar. This would be for looks (more stock), and potentially better voltage at idle (I can't get any more than 12.7-12.9 under 800 rpm).
Incidentally I've owned '64 Darts with both systems and couldn't tell a difference. Both of them seemed to have better idle output than this valiant though.
PostPosted: Thu Jan 15, 2009 10:57 am
The regulator isn't affecting your voltage at idle - look harder at your alternator.
PostPosted: Fri Jan 16, 2009 1:28 pm
Yeah it's an OEM from some early '70s mopar. I have absolutely no idea how many amps it is, but the output at idle seems real low. Full-fielding it does nothing at idle.
I posted the above before doing some more investigating. I added a proper ground from the alt case to the regulator (i've been meaning to add a ground harness for a long time), which did nothing for idle voltage but did lower the high-rpm voltage a little.
i'll check the diodes - i have a generic rebuilt alternator that I could use for parts.
PostPosted: Fri Jan 16, 2009 6:27 pm
Idle output is highly variable in the Mopar alternators. Some of them work okay at idle, and others are really weak — that's even with non-"remanufactured" units. There's also a range of pulley sizes; a smaller pulley spins the alternator faster at idle.
