It is currently Sun Nov 29, 2026 4:54 am
PostPosted: Thu Jan 15, 2009 6:42 pm
I know This is probably silly, but
If a stock slant (225) with a stock bore is 3.4" when it's bored .030" the bore is now At 3.43" Correct??
PostPosted: Thu Jan 15, 2009 6:44 pm
Yes
PostPosted: Thu Jan 15, 2009 6:59 pm
Thanks!
PostPosted: Fri Jan 16, 2009 7:32 am
:roll:
PostPosted: Fri Jan 16, 2009 2:39 pm
The reason I ask is I wasnt sure if it was .030 taken off from the centerpoint out to the edge of the circumference or if it was .030 taken off the Diameter which is .015 off from the circumference to the outer edge.
Yeah Brian, When do I get my engine hoist back - I should charge you rent!
Thanks,
