| Absurd Engine math Question https://slantsix.org/forum/viewtopic.php?t=33337 |
| Author: | Greg Ondayko [ Thu Jan 15, 2009 6:42 pm ] |
| Post subject: | Absurd Engine math Question |
I know This is probably silly, but If a stock slant (225) with a stock bore is 3.4" when it's bored .030" the bore is now At 3.43" Correct?? Thanks Greg |
| Author: | Aggressive Ted [ Thu Jan 15, 2009 6:44 pm ] |
Yes |
| Author: | Greg Ondayko [ Thu Jan 15, 2009 6:59 pm ] |
Thanks! Greg |
| Author: | Brian [ Fri Jan 16, 2009 7:32 am ] |
| Author: | Greg Ondayko [ Fri Jan 16, 2009 2:39 pm ] |
The reason I ask is I wasnt sure if it was .030 taken off from the centerpoint out to the edge of the circumference or if it was .030 taken off the Diameter which is .015 off from the circumference to the outer edge. Yeah Brian, When do I get my engine hoist back - I should charge you rent! Thanks, Greg |
