It is currently Sun Nov 29, 2026 10:43 am
 Post subject: Super Six Success!!
PostPosted: Mon Jan 19, 2009 11:52 am
On the second attempt at the Super Six Conversion I have success! Carter BBd idling smooth and fast reaction to throttle! I can't wait to drive the truck and feel the difference. (New York winter a foot of snow and three inches of road salt will delay the thrill for a while) Thank you for all of the advice and encouragement on this forum!
1956 Dodge D100 Pick up
power plant 225 slant six
PostPosted: Mon Jan 19, 2009 11:54 am
What was the problem and the solution?
PostPosted: Mon Jan 19, 2009 11:59 am
I blocked all the open ports on the carb and had another set of hands to run the ignition while I worked the throttle by hand because I did not take the time to run the new cable was able to idle the motor at about 1000rpm the turn it down to about 500rpm in park. I guess the original problem was just trying to do the key and work the carb by myself should have asked for help earlier.
Users browsing this forum: Amazon [Bot] and 9 guests
