| Super Six Success!! https://slantsix.org/forum/viewtopic.php?t=33388 |
| Author: | 56 Dodge [ Mon Jan 19, 2009 11:52 am ] |
| Post subject: | Super Six Success!! |
On the second attempt at the Super Six Conversion I have success! Carter BBd idling smooth and fast reaction to throttle! I can't wait to drive the truck and feel the difference. (New York winter a foot of snow and three inches of road salt will delay the thrill for a while) Thank you for all of the advice and encouragement on this forum! |
| Author: | Joshie225 [ Mon Jan 19, 2009 11:54 am ] |
What was the problem and the solution? |
| Author: | 56 Dodge [ Mon Jan 19, 2009 11:59 am ] |
I blocked all the open ports on the carb and had another set of hands to run the ignition while I worked the throttle by hand because I did not take the time to run the new cable was able to idle the motor at about 1000rpm the turn it down to about 500rpm in park. I guess the original problem was just trying to do the key and work the carb by myself should have asked for help earlier. |
