It is currently Fri Feb 28, 2025 10:51 am
 Post subject: A-513 Conversion
PostPosted: Sun Jan 18, 2009 11:36 am
I ran across this conversion for 1995 and older A-518 lock up overdrive transmissions not needing electronics that looks interesting:
http://www.transmissioncenter.net/SwapInformation.htm
PostPosted: Mon Jan 19, 2009 6:09 am
But is there a 518 to slant 6 adaptor???
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Jan 19, 2009 9:54 am
Don't know. Dose 727 & 518 use the same case?
PostPosted: Mon Jan 19, 2009 10:01 am
A-engine 727 and 518 and 500 and 904 trannys all have same bellhousing pattern. Some minor diffs on earlier trannys you can correct (pretty sure) with a hand drill, or leaving out a bolt or two.
