It is currently Sat Sep 19, 2026 9:41 am
 Post subject: gasket material
PostPosted: Fri Jan 23, 2009 4:14 am
Is there any difference between cork and rubber gaskets? I put a cork gasket on a car [other than my Valiant] when doing a transmission service and it's leaked ever since. I've been told that it was because of the cork gasket or lack of spooge. I'm going to do a tranny service on the Valiant before spring arrives and only want to do it once.
Ideas please???
Thanks.
Joe
PostPosted: Fri Jan 23, 2009 6:00 am
Joe
I prefer rubber. But in saying that Ive had both leak. Use what ya got. :lol:
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Jan 23, 2009 8:44 am
copied and pasted from SSDan in another post. I've used one of the rigid gaskets from the dealer. Works great
"•A 1964-up transmission pan or a brand-new pan. Nice new pans with unwarped rails can be had from the dealer under p/n 52118 779AB, and they even include a spiffy magnet to catch metallic shavings. Whether you go that route or install a used '64-up pan, save yourself a bunch of current and future hassle: Discard the floppy cork or rubber pan gasket that comes with the filter kit. Instead, from the Chrysler dealer get the really nice double-seal, reusable rigid pan gasket P/N 4295 875AC. "
Edit: assuming you have a 904 trans
PostPosted: Fri Jan 23, 2009 9:43 am
Good advice. Also make sure if you are reusing the pan that the area around the bolt holes isn't deformed and compressing the gasket just around the bolts. I usually turn the pan flange upright on a block of wood and put the ball of a ball-peen hammer in each bolt hole and know the dents back down with another hammer.
PostPosted: Fri Jan 23, 2009 10:34 am
Excellent information about the rigid pan gasket.
Thank you.
Joe
