| What could be wrong? https://slantsix.org/forum/viewtopic.php?t=33659 |
| Author: | 75plyduster [ Fri Feb 06, 2009 2:07 pm ] |
| Post subject: | What could be wrong? |
The only way I can start my car is putting a screwdriver on the starter relay. Ive replaced the starter relay already and the first few days it started normally but now it wont start with just a turn of the ignition. What could be causing this? |
| Author: | Reed [ Fri Feb 06, 2009 2:20 pm ] |
Ignition switch, neutral start switch, faulty wiring somewhere. Time to break out the test light and check for continuity. |
| Author: | '74 Sport [ Fri Feb 06, 2009 8:29 pm ] |
Start with the easiest to check first - test the neutral safety switch. Then check the wires that lead to it for melted, bare, or broken spots. Check all wires and connections to/from the starter relay. Last resort - ignition switch. |
| Author: | Roelof [ Sun Feb 08, 2009 7:10 am ] |
This happened to me a week ago. After installing a radio and replacing some dodgy wiring the car just would not start. Only the way you discribe. It took me two long evenings under the dash with a flashlight to find out that some previous owner had installed a very small anti-theft switch under the steering collumn. |
