It is currently Tue Nov 10, 2026 9:47 pm
 Post subject: What could be wrong?
PostPosted: Fri Feb 06, 2009 2:07 pm
The only way I can start my car is putting a screwdriver on the starter relay. Ive replaced the starter relay already and the first few days it started normally but now it wont start with just a turn of the ignition. What could be causing this?
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Fri Feb 06, 2009 2:20 pm
Ignition switch, neutral start switch, faulty wiring somewhere. Time to break out the test light and check for continuity.
PostPosted: Fri Feb 06, 2009 8:29 pm
Start with the easiest to check first - test the neutral safety switch.
Then check the wires that lead to it for melted, bare, or broken spots.
Check all wires and connections to/from the starter relay.
Last resort - ignition switch.
PostPosted: Sun Feb 08, 2009 7:10 am
This happened to me a week ago. After installing a radio and replacing some dodgy wiring the car just would not start. Only the way you discribe.
It took me two long evenings under the dash with a flashlight to find out that some previous owner had installed a very small anti-theft switch under the steering collumn. :)
