Compression ratio for Erson .510
https://slantsix.org/forum/viewtopic.php?t=33686
Page 1 of 1
Author:  pinkiedog64 [ Sun Feb 08, 2009 6:07 pm ]
Post subject:  Compression ratio for Erson .510
What is the "ideal" CR for the Erson .510 lift cam, assuming 4 bbl intake, headers, headwork, etc. that will be driven part street and part strip?
Author:  Michael [ Sun Feb 08, 2009 6:33 pm ]
I'm pretty sure that there is no comfortable street "part" to this cam's equation. 10:1 for openers on the strip.
Author:  Dart270 [ Mon Feb 09, 2009 4:48 am ]
A true 9.5:1 would be my absolute minimum, but that cam will work best with 10:1 - 11:1. I'd shoot for 10:1 if you want to run pump gas, although you might even get away with 11:1.
You really will want a high stall converter with this cam. For street-strip, I'd get a 3000 stall. Stick would work well too.
