It is currently Sun Jun 21, 2026 1:53 pm
 Post subject: Header collectors
PostPosted: Thu Feb 26, 2009 8:23 am
We're making some progress on the Duster again. The sheet metal intake is done so we started on building the headers. I can't seem to find anyone that makes a 3 into 1 collector. Any help is appreciated and thanks in advance.
PostPosted: Thu Feb 26, 2009 9:14 am
It depends on what size you want. The 3 into 1 are kind of small. I am planning on using the 2 into 1 collector collector
Thanks Mike
PostPosted: Thu Feb 26, 2009 9:16 am
If you want to spend a lot of money Burn Stainless has them. http://www.burnsstainless.com/MergeColl ... 1base.html
Looks like S&S makes 'em. http://www.ssheaders.com/collectors.htm
How about Stahl? http://www.stahlheaders.com/Frame%20Collectors.htm
PostPosted: Thu Feb 26, 2009 10:15 am
Thanks guy's. I see that Burn's is still quite proud of their products. lol S&S has a good price, but the wrong size. I'm using 1 3/4" stainlelss for the primaries. Also the header flange is 1 piece with both intake and exhaust ports through it. I then attached the sheet metal intake to the header flange. Once the header is completed, it'll be sent off to get ceramic coated.
PostPosted: Thu Feb 26, 2009 10:49 am
I think I'm going to have to give Stahl some business soon once fund recover.
PostPosted: Thu Feb 26, 2009 11:24 am
I liked S and S's price but they have a 25.00 minimum. You will post pic's when you have it all finished won't you?
Thanks Mike
PostPosted: Thu Feb 26, 2009 11:41 am
Will these work for you? Stans or these stainless
Thanks Mike
PostPosted: Thu Feb 26, 2009 11:55 am
Thanks. They have what I need but only in mild steel. I wish they made them in stainless. They'd be getting a call right now.
