It is currently Mon Nov 16, 2026 8:40 am
PostPosted: Sat May 23, 2009 1:02 pm
What is the best way to remove the cables from a push button trans? Should I remove the cables at the trans (not sure how anymore) or should I remove the cables from the back of the shifter mechanism (which I have never messed with)? I am taking the engine and trans out as a unit and I am keeping the speedo cable in the trans. thanks...
PostPosted: Sat May 23, 2009 4:10 pm
Online
Remove the cables from the trans. Why are you not removeing the speedo cable? It is actually easier to remove, then the cables. Call me if you wish.
 Post subject: going back under
PostPosted: Sat May 23, 2009 4:22 pm
Let me get back under there tonight and see what I can do. I found my old Valiant manual to see how the cable comes out of the trans. If I have any questions, I will call ya later. Thanks
PostPosted: Sun May 24, 2009 9:57 am
There is a little wire "clip" that holds the cable in the transmission, push the wire "just right" and the cable pops out.
The FSM does a good job showing how it's done.
