It is currently Sat Nov 21, 2026 9:28 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: Injector bosses
PostPosted: Mon Apr 01, 2002 11:46 am
How are the fuel injector guys running the injectors on to the manifold?
Is there an aluminum casting that one can weld onto the aluminum manifold?
Richard
richard-c@e-d-a.com
 Post subject: Re: Injector bosses
PostPosted: Mon Apr 01, 2002 11:57 am
: is there an aluminum casting that one can weld
: onto the aluminum manifold?
: Thanks : Richard
Richard, to put it bluntly......YES
I don't think it's a casting, but is turned out of aluminum stock. Available from MSD, from their fuel injection components parts. MSD claims that they will accept the GM injectors. Warning....MSD is a little proud of them. Locally, I was quoted $90 for a set of 8.
It's been suggested to have Clifford/Offy intake drilled at 45* right next to head mount flange for the bosses. You could then either epoxy , or have them welded into place. I think I'm going the welded route.
Roger
GTS225@aol.com
PostPosted: Mon Apr 01, 2002 12:03 pm
Holy carap that was fast! OK thanks for the info. I will look into it. I am assuming the cm ones are like the standard bash units??
: Richard, to put it bluntly......YES
: I don't think it's a casting, but is turned out
: of aluminum stock. Available from MSD, from
: thier fuel injection components parts. MSD
: claims that they will accept the GM
: injectors. Warning....MSD is a little proud
: of them. Locally, I was quoted $90 for a set
: of 8.
: It's been suggested to have Clifford/Offy
: intake drilled at 45* right next to head
: mount flange for the bosses. You could then
: either epoxy , or have them welded into
: place. I think I'm going the welded route.
: Roger
PostPosted: Tue Apr 02, 2002 10:28 am
: Holy carap that was fast! OK thanks for the
: info. I will look into it. I am assuming the
: cm ones are like the standard bash units??
Just a trick of the time zones......I just happened on at the right time.
Not sure I understand fourth sentence/question. "cm ones"....is that a typo, and you wanted to say gm ones? If so, yes, it would be the injectors that have been used pretty much since they started doing EFI.
Roger
GTS225@aol.com
PostPosted: Thu Apr 04, 2002 10:44 pm
: Just a trick of the time zones......I just
: happened on at the right time.
: Not sure I understand fourth sentence/question.
: "cm ones"....is that a typo, and
: you wanted to say gm ones? If so, yes, it
: would be the injectors that have been used
: pretty much since they started doing EFI.
: Roger
I meant to say, but I never proof, GM ones Like the Standard Bosch ones.
my other project is a subaru station wagon with a watercooled flat four, pushrod (they use it for experimental, root word MENTAL aircraft) and it is turbo'd and injected. Yours truly cracked a head and you can't find these damn things anywhere, so I wanted to ionject a non injected one. I think I would be better off making my ond bosses though as they are supposed to be the rubber hosed units so I need mount screw bosses on the heads as well as the nose seal.
Been forced to derive the valeint (darn!!!!!) and I still love her!
PostPosted: Thu Apr 11, 2002 7:15 am
: I meant to say, but I never proof, GM ones Like
: the Standard Bosch ones.
: my other project is a subaru station wagon with
: a watercooled flat four, pushrod (they use
: it for experimental, root word MENTAL
: aircraft) and it is turbo'd and injected.
: Yours truly cracked a head and you can't
: find these damn things anywhere, so I wanted
: to ionject a non injected one. I think I
: would be better off making my ond bosses
: though as they are supposed to be the rubber
: hosed units so I need mount screw bosses on
: the heads as well as the nose seal.
: Been forced to derive the valeint (darn!!!!!)
: and I still love her!
I hope everyone knows that all of the regular (non-hyperpack) 4bbl manifolds from Clifford ALREADY have these 45 degree injector bosses cast in to them. I have a WH and non-WH, both with the bosses in them. Might save a lot of time and welding...
lmadsen@email.unc.edu
