| Injector bosses https://slantsix.org/forum/viewtopic.php?t=3422 |
| Author: | Richard [ Mon Apr 01, 2002 11:46 am ] |
| Post subject: | Injector bosses |
How are the fuel injector guys running the injectors on to the manifold? Is there an aluminum casting that one can weld onto the aluminum manifold? Thanks Richard richard-c@e-d-a.com |
| Author: | GTS225 [ Mon Apr 01, 2002 11:57 am ] |
| Post subject: | Re: Injector bosses |
: is there an aluminum casting that one can weld : onto the aluminum manifold? : Thanks : Richard ************************************************** Richard, to put it bluntly......YES I don't think it's a casting, but is turned out of aluminum stock. Available from MSD, from their fuel injection components parts. MSD claims that they will accept the GM injectors. Warning....MSD is a little proud of them. Locally, I was quoted $90 for a set of 8. It's been suggested to have Clifford/Offy intake drilled at 45* right next to head mount flange for the bosses. You could then either epoxy , or have them welded into place. I think I'm going the welded route. Roger GTS225@aol.com |
| Author: | r [ Mon Apr 01, 2002 12:03 pm ] |
Holy carap that was fast! OK thanks for the info. I will look into it. I am assuming the cm ones are like the standard bash units?? Quote:
: Richard, to put it bluntly......YES : : I don't think it's a casting, but is turned out : of aluminum stock. Available from MSD, from : thier fuel injection components parts. MSD : claims that they will accept the GM : injectors. Warning....MSD is a little proud : of them. Locally, I was quoted $90 for a set : of 8. : : It's been suggested to have Clifford/Offy : intake drilled at 45* right next to head : mount flange for the bosses. You could then : either epoxy , or have them welded into : place. I think I'm going the welded route. : : Roger |
| Author: | GTS225 [ Tue Apr 02, 2002 10:28 am ] |
: Holy carap that was fast! OK thanks for the : info. I will look into it. I am assuming the : cm ones are like the standard bash units?? ************************************************* Just a trick of the time zones......I just happened on at the right time. Not sure I understand fourth sentence/question. "cm ones"....is that a typo, and you wanted to say gm ones? If so, yes, it would be the injectors that have been used pretty much since they started doing EFI. Roger GTS225@aol.com |
| Author: | Richard [ Thu Apr 04, 2002 10:44 pm ] |
: : ************************************************* : Just a trick of the time zones......I just : happened on at the right time. : : Not sure I understand fourth sentence/question. : "cm ones"....is that a typo, and : you wanted to say gm ones? If so, yes, it : would be the injectors that have been used : pretty much since they started doing EFI. : : Roger I meant to say, but I never proof, GM ones Like the Standard Bosch ones. my other project is a subaru station wagon with a watercooled flat four, pushrod (they use it for experimental, root word MENTAL aircraft) and it is turbo'd and injected. Yours truly cracked a head and you can't find these damn things anywhere, so I wanted to ionject a non injected one. I think I would be better off making my ond bosses though as they are supposed to be the rubber hosed units so I need mount screw bosses on the heads as well as the nose seal. Been forced to derive the valeint (darn!!!!!) and I still love her! |
| Author: | Dart270 [ Thu Apr 11, 2002 7:15 am ] |
: I meant to say, but I never proof, GM ones Like : the Standard Bosch ones. : : my other project is a subaru station wagon with : a watercooled flat four, pushrod (they use : it for experimental, root word MENTAL : aircraft) and it is turbo'd and injected. : Yours truly cracked a head and you can't : find these damn things anywhere, so I wanted : to ionject a non injected one. I think I : would be better off making my ond bosses : though as they are supposed to be the rubber : hosed units so I need mount screw bosses on : the heads as well as the nose seal. : : Been forced to derive the valeint (darn!!!!!) : and I still love her! I hope everyone knows that all of the regular (non-hyperpack) 4bbl manifolds from Clifford ALREADY have these 45 degree injector bosses cast in to them. I have a WH and non-WH, both with the bosses in them. Might save a lot of time and welding... Lou lmadsen@email.unc.edu |
