It is currently Fri Nov 13, 2026 10:50 pm
 Post subject: Good Coil for HEI
PostPosted: Wed Mar 11, 2009 7:53 am
Hey guys, I was wondering if this coil is good to use with the HEI conversion. This is what I have on it right now. Any input would be greatly appreciated.
http://www.pertronix.com/prod/ig/flame/ ... _volt.aspx
love always,
russ
1965 Dodge A100
PostPosted: Wed Mar 11, 2009 8:03 am
It'll probably work okeh, at least for awhile, but it's probably not the best pick. See the coil info in the HEI upgrade article.
PostPosted: Wed Mar 11, 2009 9:37 am
Dan,
I found the part that you referenced in the article. are the holes in each corner mounting holes? This will be in a Dodge A100, so it would have to be mounted to the rear dog house panel.
Thanks,
Russ
love always,
russ
1965 Dodge A100
PostPosted: Wed Mar 11, 2009 9:48 am
I've been running a Mallory Promaster coil in my truck for the last six years and it's worked outstanding. This is with a Mallory ignition piggybacked to a factory Toyota system though. I've also got a new one (same part number) to try with the HEI ignition in my Duster. It's a big'n, and won't fit in the factory coil location (which I hate anyway), but now that the MSD Blaster 2 is being made in China and the Promaster is still US-made, I figured it'd be well worth trying. Only caveat is that it uses a male HEI-style ignition lead as opposed to the common female type. I've already got a set of Magnecor wires custom ordered to accommodate it.
I honestly doubt it'll offer higher performance per se, but I think I can achieve a much cleaner and more efficient installation with this Vs. a canister type coil, and it'll likely last longer than a new MSD would now anyway.
I'll be sure to post up my results when all is said and done.
PostPosted: Wed Mar 11, 2009 9:50 am
Yes, they're mounting holes. There's a mount bracket used with this coil on all the cars that came with it.
PostPosted: Wed Mar 11, 2009 10:02 am
Dan,
Sounds like it might be a super cold day at the junkyard for me. It was -15 with the windchill earlier :( . Thanks a million for the help!!
Thanks,
Russ
love always,
russ
1965 Dodge A100
