It is currently Sat Jul 18, 2026 12:48 am
 Post subject: Wheel hop
PostPosted: Wed Mar 25, 2009 6:24 am
Does anyone have any suggestions I have a violent wheel hop problem on my 86 ram. once out of first gear it can spin the tires into smoke with no shudder. But from a dead stop up to about 10mph if it spins its so violent that when it happens if I don't get out of it immediatly I will break an axle (happened before with only 1 sec of hop)I have a pinion snubber which helped. should I install more springs? any help would be appreciated. Nick
Nick
86 d150 turbo /6.
PostPosted: Wed Mar 25, 2009 7:19 am
Traction bars are the cheapest way out. Cal-Tracs are more expensive, but work better. The GM torque arm system used on the '83 and later GM F-bodies works well too, but requires fabrication. To get a pinion snubber to do the same job it often has to be pre-loaded and/or very strong. I'd try traction bars first.
PostPosted: Wed Mar 25, 2009 10:18 am
How far away is your pinion snubber from hitting and is the contact area heavy duty enough. You must have made a bracket of some sort.
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Wed Mar 25, 2009 11:00 am
the snubber is against when I race and the bracket is angle iron.The ford 9" also has a cast shroud that protrudes over the u joint,which I am using as the bump point. The snubber is a 3" tall urethane suspension travel stop.
Nick
86 d150 turbo /6.
PostPosted: Wed Mar 25, 2009 11:04 am
:shock: Is the pinion angle causing this? You have the stock pickup springs?
PostPosted: Wed Mar 25, 2009 11:17 am
I don't think I would have tried using that cast iron shroud to prevent spring wrap. If your bumper were shorter and stouter I think you stand a good chance of breaking that little casting. I feel that traction bars that are long enough to put the bumper right under the front spring eye are your best best without spending a lot of money.
PostPosted: Thu Mar 26, 2009 5:03 pm
How far away is the snubber when resting. I'd say 1/2 - 1" works good.
PostPosted: Thu Mar 26, 2009 7:59 pm
Just my opinion, but you'd be better off to throw the pinion snubber away and put on a cheap pair of Lakewood clamp on traction bars.
Pinion snubbers only work with a really stiff spring like a SS spring or something of that nature, and it is still a band-aid on a bullet wound at best.
A snubber can still let the springs work independently, whereas a set of Lakewood bars shimmed properly will not.
You can also try clamping the front half of the springs so the leaves will not separate and leave the snubber on.
My '66 left just as hard on 8" ET Streets, Lakewood bars, and stock springs/shocks as Mike Jeffrey's '68 did with ladder bars/coilovers and 12" slicks. :shock:
PostPosted: Fri Mar 27, 2009 6:16 am
What about adding a leaf to the front and clamping them?
PostPosted: Fri Mar 27, 2009 6:12 pm
thanks for the advice everyone!
Nick
86 d150 turbo /6.
 Post subject: pictures
PostPosted: Tue Apr 07, 2009 3:25 pm
I built a track bar after much debate and plan on incorperating the drive shaft loop in with it. Here are some pictures. It seems to work well
Nick
86 d150 turbo /6.
PostPosted: Tue Apr 07, 2009 3:57 pm
I thought torque arm like that would be pretty easy to do on an 8 3/4 or a 9" without welding to the housing as long as one had access to a lathe. I would make tube nuts to replace a few of the common nuts that hold the 3rd member to the housing and bolt the torque arm to the tube nuts. The 3rd member would then act as a housing reinforcement and load spreader.
PostPosted: Tue Apr 07, 2009 4:07 pm
How big of a Lathe? Fopar and I both have lathes...
PostPosted: Tue Apr 07, 2009 5:39 pm
To make the tube nuts you'd only need to turn 3/4" round stock. My friend Bob who's only about one hour from me has a lathe and also a mill with an indexing rotary table which is great for putting the hex on the nuts. We made some for my valve covers and wire looms.
PostPosted: Tue Apr 07, 2009 6:08 pm
An hour is a bit less. Yes.
I wish I had an indexing table! :cry:
Looks good Turboram!
