It is currently Thu May 21, 2026 1:27 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: trailer hitch for Dart
PostPosted: Thu Apr 04, 2002 10:23 am
Doe anyone have a trailer hitch on their DART? I would likw to know how and where it is attached. I have a 1969 Dart and would like to pull a small fishin boat but can not find anything locally that will fit. All I find are reciever hitches for pickups and SUV's.
larry.hale@emersontool.com
PostPosted: Thu Apr 04, 2002 11:54 am
I saw one a few months ago on e-bay. It attached with a bracket that went around the license plate and bolted to the spare tire bump. I doesn't sound like any more than a class I hitch. It was also for a 65 a-body. Does anybody remember those u-haul bumper mounted hitches? When I was a kid (back in the 60's) I remember we rented a trailer and used a bolt on hitch. It kind of clamped onto the bumper. Not something you'd want to do with a modern bumper. Let me know what you find out. I want to do the same thing on my 65
Mike
My Car
MAndreas@aol.com
PostPosted: Thu Apr 04, 2002 12:02 pm
: Doe anyone have a trailer hitch on their DART?
: I would likw to know how and where it is
: attached. I have a 1969 Dart and would like
: to pull a small fishin boat but can not find
: anything locally that will fit. All I find
: are reciever hitches for pickups and SUV's.
Years ago I had a '66 Dart with a bumper hitch. It had a L shaped bracket that bolted onto the bumper behind the license plate. There was a straight piece of metal that bolted onto the bottom of the L bracket. One side went under the spare tire well and was held there with 2 bolts the other when out the rear and had the hole for the ball. Not Class 3 stuff, but it would have been OK for small trailers.
I would try a shop that specializes in hitches and trailers. They should be able to make you a hitch that fits the car.
klesteb@aol.com
PostPosted: Sun Apr 07, 2002 7:05 am
: I had the same problen finding a hith for my 78 Aspen wagon.I found a Valley universal hitch at NAPA that has worked well so far.
clark1124@aol.com
 Post subject: Mount to frame?
PostPosted: Sun Apr 07, 2002 8:56 am
Does it mount to the frame or the bumper?
Mike
MAndreas@aol.com
 Post subject: Re: Mount to frame?
PostPosted: Sun Apr 07, 2002 12:26 pm
: Mine mounts to the bumper,behind the liscence plate.4 bolts through the face of the bumper and 2 bolts through the lower bumper flange.If your car has hydraulic bumper impct shocks,you will have to make brackets to rigidly mount the bumper to the rear crossmember.These are to prevent the bumper from moving in and out when braking or accelerating.I have this setup on my Aspen wagon,and recently pulled a 1700 pound load with no problems.Of course,your mileage may vary,and past performance is not an indicator of future results.Ya pays yer money,ya takes yer chances!!!
clark1124@aol.com
