It is currently Sat Nov 21, 2026 1:32 am
PostPosted: Thu Apr 04, 2002 11:20 am
Is it possible to convert a hydraulic lifter motor to a solid lifters. I know i'll need the solid lifter rocker shaft and rockers but I'm wondering about the push rod lengths are they the same. I noticed that the hyraulic camshaft has a groove in the one journal and the solid lifter cam doesn't. any suggestions?
craig_o_connor88@hotmail.com
PostPosted: Thu Apr 04, 2002 6:12 pm
: Is it possible to convert a hydraulic lifter
: motor to a solid lifters. I know i'll need
: the solid lifter rocker shaft and rockers
: but I'm wondering about the push rod lengths
: are they the same. I noticed that the
: hyraulic camshaft has a groove in the one
: journal and the solid lifter cam doesn't.
: any suggestions?
The pushrods are also different. (ball ends on both ends, not a cup & ball like the mechanical push rods)
Also remember that the lobe profile of a mechanical cam has a softer lash "take-up / lead-in" ramp vs a more aggressive Hyd. ramp profile.
PostPosted: Thu Apr 04, 2002 7:57 pm
what I'd need is some push rods and a solid lifter cam to convert the hydraulic lifter motor over to solid lifters? or are are there other considerations
