| hydrualic to solid lifter https://slantsix.org/forum/viewtopic.php?t=3431 |
| Author: | mopar madness [ Thu Apr 04, 2002 11:20 am ] |
| Post subject: | hydrualic to solid lifter |
Is it possible to convert a hydraulic lifter motor to a solid lifters. I know i'll need the solid lifter rocker shaft and rockers but I'm wondering about the push rod lengths are they the same. I noticed that the hyraulic camshaft has a groove in the one journal and the solid lifter cam doesn't. any suggestions? craig_o_connor88@hotmail.com |
| Author: | Doctor Dodge (Doug Dutra) [ Thu Apr 04, 2002 6:12 pm ] |
| Post subject: | Re: hydrualic to solid lifter |
: Is it possible to convert a hydraulic lifter : motor to a solid lifters. I know i'll need : the solid lifter rocker shaft and rockers : but I'm wondering about the push rod lengths : are they the same. I noticed that the : hyraulic camshaft has a groove in the one : journal and the solid lifter cam doesn't. : any suggestions? The pushrods are also different. (ball ends on both ends, not a cup & ball like the mechanical push rods) Also remember that the lobe profile of a mechanical cam has a softer lash "take-up / lead-in" ramp vs a more aggressive Hyd. ramp profile. DD |
| Author: | mopar madness [ Thu Apr 04, 2002 7:57 pm ] |
what I'd need is some push rods and a solid lifter cam to convert the hydraulic lifter motor over to solid lifters? or are are there other considerations craig_o_connor88@hotmail.com |
