| 198 connecting rods https://slantsix.org/forum/viewtopic.php?t=34312 |
| Author: | RustyRamcharger [ Sun Mar 15, 2009 8:13 pm ] |
| Post subject: | 198 connecting rods |
I found a vendor that has new forged H-beam 198 connecting rods. http://www.campbellenterprises.com/slan ... g-rods.php Matching 225 high compression pistons are also available. Make sure you're sitting before you look at the prices. Ken |
| Author: | runvs_826 [ Sun Mar 15, 2009 8:31 pm ] |
Yes K1 has worked with us directly to produce those rods. They are actually very reasonably price, maybe not sbc or 302 rods. They had a small problem with the tang location, but great stuff! |
| Author: | Charrlie_S [ Mon Mar 16, 2009 3:18 am ] |
| Post subject: | Re: 198 connecting rods |
Stock 198 con rods, used (if you can find them) $200 plus at least $25 (probably more) per rod to add ARP bolts and recondition= $350.Ken So for less then $150 more you have a much stronger, lighter rod. Actually a no brainer. |
| Author: | Shaker223 [ Mon Mar 16, 2009 4:26 am ] |
The K1 and Wiesco piston packages need to be a sticky!! |
| Author: | vynn3 [ Mon Mar 16, 2009 5:12 am ] |
Quote: Stock 198 con rods, used (if you can find them) $200
Or even more, if you REALLY wanted a set, say, 2 years ago... AMHIK.
| Author: | Charrlie_S [ Mon Mar 16, 2009 5:29 am ] |
Quote: Quote: Stock 198 con rods, used (if you can find them) $200
Or even more, if you REALLY wanted a set, say, 2 years ago... AMHIK. |
