It is currently Tue Jun 23, 2026 4:03 am
PostPosted: Sun Mar 15, 2009 9:02 pm
Hello a few quick items of concern.
I have searched about this info already and just have a few things to ask.
1. Which is lighter - Tublar or stamped steel(stock) UCA's ?
2 I plan to swap Brakes / Spindles / Bolt pattern from (68 A body) Stock 9" drums with the Small upper ball joint to Volare Spindles / Discs / Calipers with big bolt pattern/ Large upper ball joint.
3.It appears this swap is easily done -Last question is about the lower ball joints. What do I need to use to make this swap successful?
Do I just use the Stock 73-up A body Lower Ball Joint in place of the FJM Steering arm?
Thanks for you paitience as I know this topic is beat to death.
PostPosted: Sun Mar 15, 2009 9:08 pm
Yes.
PostPosted: Sun Mar 15, 2009 9:11 pm
Simple enough!
Thanks!
PostPosted: Sun Mar 15, 2009 9:19 pm
Greg- Not to hijack your thread,but I sent you a pm a week or so ago,did you receive it?
PostPosted: Mon Mar 16, 2009 3:31 pm
Sorry nope not in the inbox..
Re send PM or click on the car in the sig line and find my email on the site. - I wont post it due to spam bots etc.
PostPosted: Mon Mar 16, 2009 3:56 pm
email sent :D
PostPosted: Mon Mar 16, 2009 4:04 pm
I think the tubular UCA's are maybe 0.5-1 lbs lighter per side. Hardly worth the cash. Only worth it if you want it for convenience or to get more caster/camber, or to avoid the MOOG offset bushings. The stockers only weigh about 4.5 lbs, so not much to save.
I just bought my first set of tubular UCAs on a whim. Haven't installed them yet. I bought them for the caster gain and convenience and nothing else.
PostPosted: Mon Mar 16, 2009 8:13 pm
Well Then there's a 73 Dart over at my dad's with some big ball joint UCA's i'll pick up then. i'll spend the money on some 4.5" axles.
PostPosted: Tue Mar 17, 2009 6:33 am
Good choice.
PostPosted: Tue Mar 17, 2009 5:54 pm
Yeah - This also Means the FJM spindles Off that nasty Red Lebaron wagon are no longer available - Sorry. They are going into my "racecar" which spelled backwards is "racecar"
PostPosted: Wed Mar 18, 2009 3:52 am
Racecar
That would be a Palindrome. Which just happens not to be a palindrome... Emodnilap palindrome emodnilap palindrome, nope. Boy that one flew in under the radar...
Now if we were talking about a 1961...
PostPosted: Wed Mar 18, 2009 7:10 am
Racecar, a Toyota racecar?
e.g. Dodge
PostPosted: Wed Mar 18, 2009 12:48 pm
My Race Car is a 68 Valint Junker - It's a factory Lightweight due to extensive amounts of SW PA Rust :)
PostPosted: Wed Mar 18, 2009 3:25 pm
Greg, if the car you're getting the A-arms off of still has a rear in it grab the brakes. Most of the BBP axles are set up for B or E body brakes and the spacing is different from the bearing out. SBP brakes won't work. :shock:
PostPosted: Wed Mar 18, 2009 5:39 pm
Thanks for the Tip Dennis, I also Have a bunch of F body Rear Brake parts I was planning to USe with My BBP axle Purchase, But i'll keep in in mind.
