It is currently Sun Jun 14, 2026 9:00 pm
 Post subject: more 2x1 info needed
PostPosted: Sun Mar 22, 2009 3:17 am
My #6 cyl is dead, bad valve. I have another good head so while I swap it out I was thinking of putting my 2x1 intake with 2 holley 1945's on. I was waiting until I got headers or dutra duals but since I have have to do the head swap anyways I thought I'd put it on.
Problem is, I have to have it done and tuned by Thursday evening. Preferably before that. I have been searching threads all night and have gotten some decent info, but I'm still not sure about my kick down linkage. I have a 77 truck and the throttle is a cable and the kickdown a rod. Its the same as the linkage set up on my 77 Volare' parts car.
If I'm going to need some Lockar stuff then I'll just keep the project on hold and swap heads, keep my 1bbl and be done w/ it. But if it won't be a problem, I'd like to take a shot at it and do the exhaust another day. Any photo's would be appreciated. Whether I use them now or later. Thanks guys.
Dietz
for profiles and pictures of my mopars--> http://www.fquick.com/dietz_diggler
PostPosted: Sun Mar 22, 2009 5:48 am
If your planning on swaping the head, intake, and header or dutras, I recommend renting a car Thursday morning. :P
 Post subject: 1945s
PostPosted: Sun Mar 22, 2009 9:12 am
I,ve always had trouble with 1945s I don,t have any experence tuning the 1 bbls,but you need carbs that you can get jets and other tuning parts for.
PostPosted: Sun Mar 22, 2009 10:40 am
Jets for 1945s are readily available; they're perfectly standard Holley jets. Kickdown linkage with the 2x1 for a car other than a '60-'61 Plymouth/Dart or '60-'66 A-body means a total custom job — getting it fabbed up and working, and getting the carbs tuned and synchronised, probably is not going to happen before Thursday.
PostPosted: Sun Mar 22, 2009 1:27 pm
Thanks guys, this is what I was wondering. I'm just gonna swap the head for now then, and do the 2x1 when ever I get the dutra's/headers.
So anyone know what I'll need, or have pics of this fabricated kickdown?
PostPosted: Sun Mar 22, 2009 1:56 pm
As far as I'm aware, there has not been any distillation of "the" way to put together a kickdown for a 2x1 on a cable-throttle car. See this thread for kickdown options to start from. Info on choke hookup and other logistics for 2x1 can be found here.
