It is currently Sun Jun 14, 2026 8:05 pm
 Post subject: Radiator hose question
PostPosted: Sun Mar 22, 2009 3:39 pm
I discovered a leak in my rad today while I was installing my new torsion bars. Lucky for me, I have a 22" rad from a 1980 Aspen to replace it with. Unlucky for me, the upper inlet on the new rad is 1¼" whereas the rad hose is 1½". Is there a hose that will adapt from the 1½" outlet on the water pump to the 1¼"
inlet on the rad? Any other way to make this work?
Thanks in advance,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Sun Mar 22, 2009 3:43 pm
What year and model is your car?
PostPosted: Sun Mar 22, 2009 3:48 pm
Sorry :oops: It's a 1970 Dart.
PostPosted: Sun Mar 22, 2009 4:27 pm
slip a short length (2") of the 2 .25 hose over the rad inlet. Install the 2.5 hose over the 2.25 hose and clamp.
PostPosted: Sun Mar 22, 2009 4:34 pm
I thought about that, but I wasn't sure if it was kosher. Should I double clamp it?
PostPosted: Sun Mar 22, 2009 4:38 pm
Done right you only need one clamp and it looks stock.
I wont tell.....
PostPosted: Sun Mar 22, 2009 4:41 pm
I will.The Mopar Gods will not be pleased! :lol: I did this same swap in my 70 Dart,I thought I just used a f body hose and it all worked. May have had to trim it....
PostPosted: Sun Mar 22, 2009 4:49 pm
Cerebus ....Gawd of Mope Arse
I think you are right on the Volare hose.....Im just kinda cheap.
PostPosted: Mon Mar 23, 2009 12:22 am
Tell me about it.The hose I used was the one connected to the rad in the junk yard :shock: It looked new,and the owner let me have it for free!
PostPosted: Mon Mar 23, 2009 5:50 am
I have a '79 Volare radiator in my 72 Duster. Buy the 79 hose! No brainer.
PostPosted: Mon Mar 23, 2009 8:10 pm
Just checked the napaonline site and you've got it pegged. Thank you sir.
Nat
