| Radiator hose question https://slantsix.org/forum/viewtopic.php?t=34441 |
| Author: | NewSlanter [ Sun Mar 22, 2009 3:39 pm ] |
| Post subject: | Radiator hose question |
I discovered a leak in my rad today while I was installing my new torsion bars. Lucky for me, I have a 22" rad from a 1980 Aspen to replace it with. Unlucky for me, the upper inlet on the new rad is 1¼" whereas the rad hose is 1½". Is there a hose that will adapt from the 1½" outlet on the water pump to the 1¼" inlet on the rad? Any other way to make this work? Thanks in advance, Nat |
| Author: | SlantSixDan [ Sun Mar 22, 2009 3:43 pm ] |
What year and model is your car? |
| Author: | NewSlanter [ Sun Mar 22, 2009 3:48 pm ] |
Sorry |
| Author: | sandy in BC [ Sun Mar 22, 2009 4:27 pm ] |
slip a short length (2") of the 2 .25 hose over the rad inlet. Install the 2.5 hose over the 2.25 hose and clamp. |
| Author: | NewSlanter [ Sun Mar 22, 2009 4:34 pm ] |
I thought about that, but I wasn't sure if it was kosher. Should I double clamp it? |
| Author: | sandy in BC [ Sun Mar 22, 2009 4:38 pm ] |
Done right you only need one clamp and it looks stock. I wont tell..... |
| Author: | GENT [ Sun Mar 22, 2009 4:41 pm ] |
I will.The Mopar Gods will not be pleased! |
| Author: | sandy in BC [ Sun Mar 22, 2009 4:49 pm ] |
Cerebus ....Gawd of Mope Arse I think you are right on the Volare hose.....Im just kinda cheap. |
| Author: | GENT [ Mon Mar 23, 2009 12:22 am ] |
Tell me about it.The hose I used was the one connected to the rad in the junk yard |
| Author: | Rug_Trucker [ Mon Mar 23, 2009 5:50 am ] |
I have a '79 Volare radiator in my 72 Duster. Buy the 79 hose! No brainer. |
| Author: | NewSlanter [ Mon Mar 23, 2009 8:10 pm ] |
Quote: I have a '79 Volare radiator in my 72 Duster. Buy the 79 hose! No brainer.
Just checked the napaonline site and you've got it pegged. Thank you sir.Nat |
