It is currently Mon Nov 23, 2026 5:01 am
PostPosted: Wed Apr 01, 2009 12:34 pm
Just bought off ebay,seller said it was 490 cfm,but I want to double check before fabricating stuff for install.# cast on top near choke horn is 6R4208,# stamped on side of choke horn is 8007 and 3442.Carb is 4bbl, vacuum sec.and elec.choke. Thank you.
PostPosted: Wed Apr 01, 2009 12:39 pm
If R-8007 is on the front of the choke horn that's a 390 CFM Holley 4160.
http://www.holley.com/data/TechService/ ... isting.pdf
PostPosted: Wed Apr 01, 2009 12:57 pm
None of those numbers is in the Holley master catalogue...are there any more? Maybe with the word "LIST" before them?
PostPosted: Wed Apr 01, 2009 4:10 pm
bigslant6fan
Put a zero and a dash before 8007; = Holley part number 0-8007. Holley lists all their parts referenced to 0-8007. Summit & Jegs etc. use 4160 as a part number. Go figure!
A list of places to get that carburetor running like new, and adapted to a slant six:
Look here for Holley part number 0-8007 (known as a # 4160, 390 cfm carburetor) instructions.
Here for technical support.
Here, and Jegs, etc. for parts and rebuild kits.
 Post subject: carb
PostPosted: Wed Apr 01, 2009 8:03 pm
Thanks everyone,390cfm is what I wanted to hear.
