It is currently Tue May 19, 2026 5:54 pm
PostPosted: Wed Apr 01, 2009 7:41 am
we have a 1968 Dart...our parts Dart so to speak..want to conver to to a 4 speed overdrive...will there be a crankshaft issue as far as the trans mainshaft goes..I know there is on a 440 motor..thanks!
PostPosted: Wed Apr 01, 2009 11:31 am
If you have a small V8 you are good....the slant needs a crank and bellhousing dapter
PostPosted: Wed Apr 01, 2009 11:51 am
Would a 4 speed transmission out of a '72 Charger with 340 V8 swap onto a 225 slant in a '74 Dart? Were do the adapter for bellhousing and crank come from?
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Wed Apr 01, 2009 2:08 pm
Ahhh you mean a 4 speed manual trans......
you need a slant flywheel and bell housing.
PostPosted: Thu Apr 02, 2009 6:05 am
72 Charger is a B body. It used a different tail housing and mounted the shifter in a different spot than the A body Dart.
I don't think you can use it.
PostPosted: Thu Apr 02, 2009 7:02 am
Thanks Greg, that is what I was wondering, if it would even fit.
PostPosted: Thu Apr 02, 2009 5:22 pm
Yes, B-body will fit, but will require some work. Check this link .
http://www.bigblockdart.com/techpages/abconv.shtml
