| What are the causes of oil usage? https://slantsix.org/forum/viewtopic.php?t=34702 |
| Author: | Bren67Cuda904 [ Sun Apr 05, 2009 7:21 am ] |
| Post subject: | What are the causes of oil usage? |
It pains me to ask such a question but it is what it is. A little background: When the engine was first built it didn't burn a drop of oil. It has Total Seal gapless rings and bronze valve guides with Viton valve seals. Engine at this point had maybe 2500-3000 miles on it and didn't use oil. Decided to lower the compression: Pulled the piston and milled some off the top (where nitrous spec'd) and opened up the chambers some to bring CR down to 9.25 from 10.25. Reused the Viton valve seals and reinstalled the same rings (gapless) in same holes. Engine now uses about a quart every 700 to 1000 miles. Just changed cam to a smaller one and at that time changed out the valve seals from the Viton to the rubber/teflon ones. Engine seems to still smoke the same blue/white as before. Engine uses NO coolant. When starting there is always a little cloud and I am OK with that, although it more cloud that it should be. When driving off from any stop light or stop sign there is enough of a cloud that the drivers behind me seem to hesitate before leaving also. I've also tried to leave the line very softly as to minimize the smoke, but this seems to have very little effect. At idle there are little puffs of blue/white smoke. I am using Rotella 15-40 Check compression: 210,215,214,217,216,219 Where do you think my problem is? |
| Author: | sandy in BC [ Sun Apr 05, 2009 7:33 am ] |
Sounds like valve guides. What condition is your PCV in? |
| Author: | Shaker223 [ Sun Apr 05, 2009 8:23 am ] |
"At idle there are little puffs of blue/white smoke." = Guides or a seal(s) were damaged upon installation. |
| Author: | slantzilla [ Sun Apr 05, 2009 9:25 am ] |
D. Hookers Actually you could go with "All of the above". Personally I'd never run gapless rings in a street motor. Ring life is none too good in a race motor, let alone in a street motor with thin cylinder walls. Another personal belief is that Viton seals have no place on the street. I put heads together with an umbrella seal on the intake and nothing on the exhaust. I'd rather have good guides and deal with a little oil use than try and really control oil usage and end up with wiped out guides. That's just me though. |
| Author: | Eric W [ Sun Apr 05, 2009 9:52 am ] |
I'll bet the problem lies in the fact you reused the rings. |
| Author: | 68barracuda [ Sun Apr 05, 2009 10:00 am ] |
Personally I never reuse rings and seals/gaskets... |
| Author: | Bren67Cuda904 [ Sun Apr 05, 2009 10:04 am ] |
Quote: Sounds like valve guides. What condition is your PCV in?
PCV= still rattlesI don't see how its possible for valve guide to wear out in 6000 miles. The guides were new bronze inserts. |
| Author: | Bren67Cuda904 [ Sun Apr 05, 2009 10:08 am ] |
The rings where over $200 for the set with only 3000 miles on them tops. I don't see the problem with reusing them in the same hole. If I where to use new rings, wouldn't I have needed to rehone the cylinders to get them to break in. |
| Author: | slantzilla [ Sun Apr 05, 2009 12:28 pm ] |
Re-using rings is always a crap shoot. My concern would be using gapless to start with. 6000 miles may not seem like much, but if you have sealed all the oil out of them and run unleaded fuel that could easily kill them. 700-1000 miles a quart is really not excessive for the overbore you have. Are you sure it's not pig rich at idle? |
| Author: | sandy in BC [ Sun Apr 05, 2009 2:10 pm ] |
You can wear out guides in 500 miles if they dont oil...... If your valve train geometry is off you will wear out guides faster. |
| Author: | SlantSixDan [ Sun Apr 05, 2009 5:52 pm ] |
The symptoms as described remind me very much of what happened when I used Total Seal rings, and this topic reminds me very much of having said so several times when Brennan was asking about rings a long time ago. But I could be misremembering or something. |
| Author: | Bren67Cuda904 [ Thu Apr 09, 2009 12:35 pm ] |
I have taken some video of the tailpipe. First video is the first start of the day. Engine is Cold. http://www.youtube.com/watch?v=-t0R8QGThrg Second video is after warm up. http://www.youtube.com/watch?v=edOTAACi7Qs I think its a ring cylinder issue. What do you guys think? |
| Author: | ceej [ Thu Apr 09, 2009 12:53 pm ] |
| Post subject: | I vote rings. |
I have exactly the same problem. Guides and seals replaced when I re-worked the valves. Still, puff of smoke on launch or fire up. Total seal rings. Never again. When I pull the motor down next winter I'm going to install iron rings and be done with it. One builder suggested the long stroke was allowing the rings to unload. Maybe. Oil control has been an issue with these rings for many people. CJ Edit: Yours doesn't smoke anywhere near as much as mine does!
