It is currently Thu Nov 05, 2026 1:54 pm
 Post subject: strange spark at coil??
PostPosted: Thu Apr 09, 2009 9:44 pm
Chasing down a small clicking noise, I just found that when I turn my ignition switch OFF, there's a small single spark at the coil. When I pulled the coil wire off the coil & held it close to the coil where it plugs in, the spark will jump to the coil wire. '64 A100 van W/ stock 225. Any ideas??
PostPosted: Thu Apr 09, 2009 10:59 pm
No electronic ignition?
PostPosted: Thu Apr 09, 2009 11:04 pm
sorry, forgot to say I have a pertronix on it
PostPosted: Thu Apr 09, 2009 11:23 pm
Yep, that's it. Dumb electronic ignitions keep the coil full on most of the time and turning off the ignition causes the unit to switch off the coil which produces a spark. Perfectly normal behavior.
PostPosted: Thu Apr 09, 2009 11:45 pm
I've seen them spark when you first turn them on too... Chris got to experience that first hand, he was the one that got bit!
:lol:
~THOR~
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
