Still no start
https://slantsix.org/forum/viewtopic.php?t=34766
Author:  75plyduster [ Wed Apr 08, 2009 7:33 pm ]
Post subject:  Still no start
On my 75 duster I cant get it to turn over. I put a new neutral safety switch and starter relay, but when I turn the key nothing happens. what could be causing this?
Author:  ceej [ Wed Apr 08, 2009 8:36 pm ]
Have you disconnected the harness and done a ring test on the switch itself?
Automatic transmission? The neutral switch can be damaged if you over-tighten it. Don't know on the manual. Never had one.
CJ
Author:  75plyduster [ Wed Apr 08, 2009 8:58 pm ]
Its an auto. I made sure I didnt over tighten it.
Author:  SlantSixDan [ Thu Apr 09, 2009 4:21 am ]
See here.
Author:  75plyduster [ Tue Apr 21, 2009 3:15 pm ]
So I got to looking at it and the car will turn over if I put a screw driver on the starter relay. And the starter cranked when I put a screw driver on the wires from the batter. So I am thinking its the ignition switch because the switch will turn even without a key in it.
Author:  Reed [ Tue Apr 21, 2009 3:17 pm ]
I second the switch. There is definitely something wrong with at least the lock cylinder, and if that is messed up, chances are the ignition switch is messed up too.
