It is currently Sat Nov 07, 2026 3:56 pm
 Post subject: Still no start
PostPosted: Wed Apr 08, 2009 7:33 pm
On my 75 duster I cant get it to turn over. I put a new neutral safety switch and starter relay, but when I turn the key nothing happens. what could be causing this?
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Wed Apr 08, 2009 8:36 pm
Site Admin
Have you disconnected the harness and done a ring test on the switch itself?
Automatic transmission? The neutral switch can be damaged if you over-tighten it. Don't know on the manual. Never had one.
CJ
PostPosted: Wed Apr 08, 2009 8:58 pm
Its an auto. I made sure I didnt over tighten it.
Ronnie
PostPosted: Thu Apr 09, 2009 4:21 am
See here.
PostPosted: Tue Apr 21, 2009 3:15 pm
So I got to looking at it and the car will turn over if I put a screw driver on the starter relay. And the starter cranked when I put a screw driver on the wires from the batter. So I am thinking its the ignition switch because the switch will turn even without a key in it.
Ronnie
PostPosted: Tue Apr 21, 2009 3:17 pm
I second the switch. There is definitely something wrong with at least the lock cylinder, and if that is messed up, chances are the ignition switch is messed up too.
