It is currently Tue Nov 24, 2026 6:08 am
 Post subject: Cigarette lighter socket
PostPosted: Sat Apr 18, 2009 2:25 am
The cigarette lighter socket in the dash is rattling around and driving me nuts.
From feel, there's a 90 degree connector for the wire and the socket seems to just be snapped in.
So I figure that I'll pull the fuse, then the wire and just get the socket out of the dash and either add a o-ring or gasket or RTV so it doesn't rattle.
Is the socket in fact just pushed/snapped in?
And does it just pull out, or is there some trick to getting the socket out?
PostPosted: Sat Apr 18, 2009 3:35 am
The rear housing of the lighter behind the dash screws onto the front portion of the lighter sticking through from the front of the dash. Reach in behind and take a turn on it while holding the front portion stationary. That should tighten her up.
PostPosted: Sat Apr 18, 2009 5:16 pm
Well, it wouldn't tighten; but it loosened............. :(
So I took it out and couldn't see any reason why it wouldn't tighten.
Put it back in, and.........
it tightened :D
whatever 8)
thanks
Users browsing this forum: Bing [Bot] and 7 guests
