It is currently Tue Nov 24, 2026 4:59 am
 Post subject: engine removal
PostPosted: Thu Apr 16, 2009 7:58 am
i'm pulling an engine/trans from a 63 d100 sat and am wondering the minimaL number of tools required and what they are in order to accomplish this. I will be far from my tool box so a stripped down list of things would be nice. experienced engine/trans pullers please chime in, thanks Linc
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Thu Apr 16, 2009 3:00 pm
Just off the top of my head, you will need open/box end wrenches from 3/8" to 5/8", 3/8" to 3/4" sockets, extension, and ratchet for the motor mounts, a couple screwdrivers, and a pair of medium sized Channellocks just in case.
Hook the chain short and you'll get away without having to pull the hood if you're using a cherry picker type engine hoist.
PostPosted: Thu Apr 16, 2009 4:14 pm
Poser
Buy yourself one of those 5 gallon bucket organizers. $10.00 bucks or so from Loews. Fill it. You will be fine.
PostPosted: Thu Apr 16, 2009 4:37 pm
All that, and also add a floor jack of some kind to hold up the trans... you don't want to let it hang in there. Plus it will make re-installation alot easier.
~THOR~
PostPosted: Thu Apr 16, 2009 4:43 pm
All of the above+ BFH!
PostPosted: Fri Apr 17, 2009 6:28 am
Linc
Also depending on the terrain...Plywood to scoot the cherrypicker around on and wheel Chocks. Also a bucket for bolts and bolt-ons.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: thanks for the heads up!
PostPosted: Fri Apr 17, 2009 6:52 am
thanks for the helpful info. This engine is going to be a 100 shot 2 barrel with the an erson cam, head shave and long tube headers. I cant wait to do my first build...I plan on doing this build early 2010. Any nitrous build "tips" would be appreciated..
PostPosted: Fri Apr 17, 2009 7:05 am
PB Blaster
 Post subject: pb
PostPosted: Fri Apr 17, 2009 8:26 am
nothing gets it faster than Pb blaster! gOOD CALL, GOTTA THROWE IT IN THE CAR RIGHT NOW...
PostPosted: Fri Apr 17, 2009 10:06 am
Build it with FORGED parts and use ARP fasteners. Keep it in tune. Talk to Big D (zilla)
Frank :D :D :D
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: even at 100
PostPosted: Fri Apr 17, 2009 11:20 am
even at a 100 shot, PM'ing the 'ZILLA, thanks for the heads up, as i'm hoping for a low buck build.
