It is currently Fri Nov 06, 2026 3:58 am
 Post subject: Overcharging?
PostPosted: Wed Apr 22, 2009 7:11 am
Car Model: 1986 D100 /6 A833od shortbox
I have an 86 Dodge Ram D100. Got a new alternator and battery in March, and yesterday the battery was boiling. Distributor said it was my charging system and not the battery. My dash gauge AND my hand held voltmeter say the systems checking out at about 12.75 idle and 14 at speed. I can turn a wrench, but electrical mystifies me. Is this about right for charging? Is the battery rep just trying to pass the buck?
PostPosted: Wed Apr 22, 2009 9:49 am
Voltge Regulator?
PostPosted: Wed Apr 22, 2009 10:45 am
Try to make sure you have a good ground between the VR and body. Take it off and scrape the contact area real good. Some vaseline between the two can help prevent corrosion.
