It is currently Tue Nov 17, 2026 10:21 pm
PostPosted: Mon Apr 22, 2002 11:14 am
I am having some problems with my 75 dart. Sometimes it starts, sometimes it does not.
When I turn the key it either starts right up,
or is totally responseless.
The battery and starter are fine, the dome light
works clear and bright. I have noticed that if I
mess with the door buzzer connection under the seat (plug in then unplug), it starts (sometimes).
I am guessing that the problem is with some internal wiring as I have replaced the ballast resistor a couple of years ago.
Any expertise would be appreciated.
dodgedart75@hotmail.com
PostPosted: Mon Apr 22, 2002 12:08 pm
: I am having some problems with my 75 dart.
: Sometimes it starts, sometimes it does not.
: I have noticed that if I mess with the door
: buzzer connection under the seat (plug in then
: unplug), it starts (sometimes).
Hmmmm.....'75 Dart.....isn't that about the time that the big three was using those imbedded seat switches that had something to do with the start circuit and seat belt circuit? Might be worth getting hold of a GOOD electrical schematic to check out.
Roger
GTS225@aol.com
