It is currently Tue Nov 17, 2026 8:25 pm
PostPosted: Fri May 01, 2009 9:44 am
I just had a guy here take out my 4:10 gears and replace with 3:55 ring and pinion, new internals and new main bearings. I now have a whining at very slow speed and at high speed. Any ideas whether bearings are bad or work was bad? :(
David at the Beach in NC
PostPosted: Fri May 01, 2009 12:05 pm
Were the axle bearings replaced at the same time? If I were you, I'd contact the mechanic that did the work, before too much time elapses. Just to let him know about the noise.
 Post subject: rearend gear change
PostPosted: Sat May 02, 2009 8:01 am
Charlie down in Florida says it sounds as if the gear mesh was not done properly and that a specialty tool is required. Going to try to find a rearend specialty shop. Thanks for any input.
PostPosted: Sat May 02, 2009 9:19 am
Some aftermarket gears are just inherently noisy, even when correctly installed. There are warnings about them on many of the sites that sell gears. OEM gears seem to be the quietest.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun May 03, 2009 5:01 am
Were they new gears or used? If they were new you may be able to get the whine out. Used gears may never quiet down.
I would bet the pinion depth is off.
PostPosted: Sun May 03, 2009 7:03 am
I am going to try and find someone that does rearend work and has the depth tool. Thanx.
PostPosted: Sun May 03, 2009 7:30 am
A good rear end guy won't need the tool, but will have one anyway. :D
You can set the gears up properly w/o the depth tool IF you read the pattern correctly when you do the pattern check. The tool does make it easier to hit the pattern on the first try though.
PostPosted: Sun May 03, 2009 8:54 am
Thanx for the input guys. Wish me luck. :D
PostPosted: Sun May 03, 2009 4:49 pm
Good luck! :D
