It is currently Tue Nov 17, 2026 8:00 pm
PostPosted: Fri May 01, 2009 11:45 pm
aaaaaaaaaaaaaaaah!!!!
Can't seem to find that anywhere and I really need it to put my rusty bucket back on the road!
Where the hell does each cooler line go? Back of the trans to which one on the rad? Front of the trans...?
Everything's stock...
Thanks for the help!
Marc
PostPosted: Sat May 02, 2009 9:13 am
There are two fittings on the driver's side of the transmission. There are two similar fittings at the bottom of the radiator, facing rearward. These are where the lines connect. If your radiator hasn't got any such fittings, it is from a car with a manual transmission, and you will either need an auto-trans radiator or an external fluid cooler. See also this thread.
PostPosted: Sat May 02, 2009 2:14 pm
Hi Dan,
Yes my rad has the two fittings, my question was about if there was a way of connecting them (e.g : the right one with the most rear one etc etc...)
PostPosted: Sat May 02, 2009 6:31 pm
No, either way is okeh.
PostPosted: Sun May 03, 2009 4:16 am
Just a FYI. The front fitting on the trans is the pressure output to the cooler. The rear fitting on the trans is the return from the cooler.
