It is currently Tue Nov 17, 2026 6:30 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
PostPosted: Tue Apr 23, 2002 5:40 pm
Apparently my old style timing chain has stretched on my 68 Dart 225. Question: Do I have to replace the crank gear also, or just the cam gear and chain? Can this be done with the engine in the car? Do I have to pull the pan or replace the pan gasket when doing this? This is a stock engine that has not been rebuilt, and I will be getting a stock replacement timing set. Any help appreciated.
usclstaffingnet@sprintmail.com
PostPosted: Tue Apr 23, 2002 6:08 pm
Not a problem! You will have to remove the radiator to get at the timing gear cover, but it's easy, and the engine can stay in the car.
You can order just a chain, but I always replace the gears and chain as a set. The stock set is less than $40 at NAPA.
About the only special tool you will need is a puller, and you can rent that for a few dollars.
: Apparently my old style timing chain has
: stretched on my 68 Dart 225. Question: Do I
: have to replace the crank gear also, or just
: the cam gear and chain? Can this be done
: with the engine in the car? Do I have to
: pull the pan or replace the pan gasket when
: doing this? This is a stock engine that has
: not been rebuilt, and I will be getting a
: stock replacement timing set. Any help
: appreciated.
lancer_41@excite.com
PostPosted: Tue Apr 23, 2002 7:05 pm
and yes and yes to the oil pan and gasket. Don't forget the front main seal, while you're at it. I prefer to line up the timing marks BEFORE I tear it all down. Makes the assembly a little easier.
Gilly
tlg225ccr@aol.com
PostPosted: Tue Apr 23, 2002 9:55 pm
You shouldn't have to do anything with the pan. The rubber gasket for the front of the pan should be with the timing cover set.
slantzilla@excite.com
