| Timing Gear/Chain Replacement Help! https://slantsix.org/forum/viewtopic.php?t=3517 |
| Author: | JamesM [ Tue Apr 23, 2002 5:40 pm ] |
| Post subject: | Timing Gear/Chain Replacement Help! |
Apparently my old style timing chain has stretched on my 68 Dart 225. Question: Do I have to replace the crank gear also, or just the cam gear and chain? Can this be done with the engine in the car? Do I have to pull the pan or replace the pan gasket when doing this? This is a stock engine that has not been rebuilt, and I will be getting a stock replacement timing set. Any help appreciated. usclstaffingnet@sprintmail.com |
| Author: | Gary [ Tue Apr 23, 2002 6:08 pm ] |
| Post subject: | Re: Timing Gear/Chain Replacement Help! |
Not a problem! You will have to remove the radiator to get at the timing gear cover, but it's easy, and the engine can stay in the car. You can order just a chain, but I always replace the gears and chain as a set. The stock set is less than $40 at NAPA. About the only special tool you will need is a puller, and you can rent that for a few dollars. Quote:
: : Apparently my old style timing chain has : stretched on my 68 Dart 225. Question: Do I : have to replace the crank gear also, or just : the cam gear and chain? Can this be done : with the engine in the car? Do I have to : pull the pan or replace the pan gasket when : doing this? This is a stock engine that has : not been rebuilt, and I will be getting a : stock replacement timing set. Any help : appreciated. lancer_41@excite.com |
| Author: | Tom Gilsdorf [ Tue Apr 23, 2002 7:05 pm ] |
and yes and yes to the oil pan and gasket. Don't forget the front main seal, while you're at it. I prefer to line up the timing marks BEFORE I tear it all down. Makes the assembly a little easier. Gilly tlg225ccr@aol.com |
| Author: | dschumers [ Tue Apr 23, 2002 9:55 pm ] |
You shouldn't have to do anything with the pan. The rubber gasket for the front of the pan should be with the timing cover set. slantzilla@excite.com |
