It is currently Tue Nov 17, 2026 1:16 pm
PostPosted: Fri Apr 26, 2002 10:42 am
Can anyone give me some pointers on tracking down a transmission leak.
I have a 63 Valiant with a 3 speed auto transmission. I'm not sure which one it is.
I have never done any type of transmission work, so I don't really have a clue.
Any help is appreciated.
John
Killin5@yahoo.com
PostPosted: Sat Apr 27, 2002 7:25 am
I too need too know how to identify the transmission I have in my 1966 Dart GT /6 225.
: Can anyone give me some pointers on tracking
: down a transmission leak.
: I have a 63 Valiant with a 3 speed auto
: transmission. I'm not sure which one it is.
: I have never done any type of transmission
: work, so I don't really have a clue.
: Any help is appreciated.
: John
kimpelt@pdx.edu
PostPosted: Sat Apr 27, 2002 10:36 am
: I too need too know how to identify the
: transmission I have in my 1966 Dart GT /6
: 225.
Both are generally called 904 Torqueflites (sp?)
66 was a "transition year", these have a mechanical shift linkage, 60 - 65 had the cable linkage.
On the leaking 63 904, (cable or "flange type") the most common places they leak from is out of the small seal where the kickdown lever goes into the case. Also inspect the cables themselfs, (2 cables, one for shifting, one for "park") these cables will leak if the housing has been damaged or burned-away from laying on the nearby exhaust pipe.
