It is currently Mon Jun 15, 2026 3:34 am
 Post subject: OMC marine
PostPosted: Tue May 12, 2009 7:07 pm
hello. a while back i was given a OMC /6. is there anything unique about these? thanks, Andy.
PostPosted: Tue May 12, 2009 8:06 pm
The block and head are same as passenger car, but much of the rest of the equipment is different. Water pump, oil pan, valve cover, manifolds, ignition, etc.
PostPosted: Tue May 12, 2009 10:20 pm
and ---- if it originally started life as part of a twin engine setup,it MIGHT be reverse rotation :( .I have seen a couple,and an ad for a pair only a couple of years ago.
regards,Rod :D
PostPosted: Wed May 13, 2009 5:38 am
Is there a difference on the thrust bearings and crank in boat motors?
PostPosted: Wed May 13, 2009 6:26 pm
There were both cast and forged crank marine engines so, yes.
PostPosted: Thu May 14, 2009 2:02 am
So no difference in cranks between marine and auto. OK thanky's :D
PostPosted: Thu May 14, 2009 7:15 am
I didn't say that. If the engine truly came from Chrysler Marine and Industrial the crank may not have been drilled for a pilot bearing.
PostPosted: Thu May 14, 2009 9:56 am
If reverse rotation the rear main surface groves/lines will then direct oil out of the seal instead of back inside when used in standard rotation engine.
hey yall
leaving you so far behind you need a time machine to catch up
 Post subject: re
PostPosted: Thu May 14, 2009 6:56 pm
would this be a 225?
