OMC marine
https://slantsix.org/forum/viewtopic.php?t=35310
Author:  akbmotorsports [ Tue May 12, 2009 7:07 pm ]
Post subject:  OMC marine
hello. a while back i was given a OMC /6. is there anything unique about these? thanks, Andy.
Author:  SlantSixDan [ Tue May 12, 2009 8:06 pm ]
The block and head are same as passenger car, but much of the rest of the equipment is different. Water pump, oil pan, valve cover, manifolds, ignition, etc.
Author:  walpolla [ Tue May 12, 2009 10:20 pm ]
and ---- if it originally started life as part of a twin engine setup,it MIGHT be reverse rotation :( .I have seen a couple,and an ad for a pair only a couple of years ago.
regards,Rod :D
Author:  Rug_Trucker [ Wed May 13, 2009 5:38 am ]
Is there a difference on the thrust bearings and crank in boat motors?
Author:  Joshie225 [ Wed May 13, 2009 6:26 pm ]
There were both cast and forged crank marine engines so, yes.
Author:  Rug_Trucker [ Thu May 14, 2009 2:02 am ]
So no difference in cranks between marine and auto. OK thanky's :D
Author:  Joshie225 [ Thu May 14, 2009 7:15 am ]
I didn't say that. If the engine truly came from Chrysler Marine and Industrial the crank may not have been drilled for a pilot bearing.
Author:  passing you [ Thu May 14, 2009 9:56 am ]
If reverse rotation the rear main surface groves/lines will then direct oil out of the seal instead of back inside when used in standard rotation engine.
hey yall
Author:  akbmotorsports [ Thu May 14, 2009 6:56 pm ]
Post subject:  re
would this be a 225?
