225 Engine oil pump leak
https://slantsix.org/forum/viewtopic.php?t=35381
Page 1 of 1
Author:  Duster 73 [ Sun May 17, 2009 8:39 am ]
Post subject:  225 Engine oil pump leak
I have a 1973 Duster with a 225.The oil pump appears to be leaking between the block and the pump.I have a new gasket.Any suggestions on how to proceed would be a great help.Thanks Paul :D
Author:  Joshie225 [ Sun May 17, 2009 8:57 am ]
The factory service manual outlines how to jack up the engine and remove the oil pump.
Author:  Duster 73 [ Sun May 17, 2009 9:10 am ]
I don't have a factory manual and I was not sure if there might be a timing or other issue with the R/R of the pump.Thanks Paul
Author:  slantzilla [ Sun May 17, 2009 10:46 am ]
If you get the motor jacked up high enough, the pump is an easy out and back in. It does not have to be timed.
Make sure to take the cover off and pack the gears in vaseline before you put the pump back in.
Author:  SlantSixDan [ Sun May 17, 2009 11:37 am ]
Packing the pump should only be necessary with a brand new (dry) pump. If we're just pulling the pump, replacing the gasket, and reinstalling the pump, it won't lose its prime and no disassembly or packing should be needed.
Unfasten the right-side engine mount, put a sturdy and stable board between your floor jack and the engine oil pan, and carefully start jacking. The engine will pivot about the left-side engine mount and eventually you will have enough clearance to R&R the oil pump. If the car has A/C, make sure you don't jack the engine so high as to damage any refrigerant hardlines that might be close to the valve cover.
Author:  Duster 73 [ Sun May 17, 2009 2:53 pm ]
Thanks to all for the information.I am going to attack this project in the morning.Paul
