It is currently Sat Dec 27, 2025 12:57 pm
PostPosted: Sun May 24, 2009 10:58 am
Poser
Early 70's head. Rectangular bosses between cyl one and two and five and six. These are not the threaded bosses that allow for engine pulling. These look like dead weight (however small). Can these be ground off flush with the head or will a leak spring? Thanks, Wayne.
PostPosted: Sun May 24, 2009 11:10 am
Site Admin
Post us a photo. :D
CJ
PostPosted: Sun May 24, 2009 11:37 am
Poser
Challenging "the challenged" aren't you! :D :D :D
PostPosted: Sun May 24, 2009 11:53 am
I know if you put to long of a bolt in them it will spring a leak......I had to install a lifting stud and JB Weld it in to keep it from leaking. Grinding off the boss shouldn't hurt.
PostPosted: Sun May 24, 2009 12:04 pm
Site Admin
If your talking about the bosses that stand out from the deck area on the side of the block, on the freeze plug side, Then yes, you can grind them off.
I had to grind a large part of mine off to clear my manifolds after cutting the deck. There is a lot of material there, though there is a concern about removing stiffness from the engine by removing them.
They look like this on an unmolested motor:
This is what we're talking about here, right?
CJ
PostPosted: Sun May 24, 2009 12:30 pm
Poser
Not exactly. The flat surface on top of the head inbetween the valve cover and the edge of the head where intake /exhaust bolts up. Four bosses located there. Two are threaded for engine removal, two are not. The untapped rectangular "chunks" are what I am thinking of removing. Thanks for you patience!
PostPosted: Sun May 24, 2009 1:03 pm
This?
PostPosted: Sun May 24, 2009 1:58 pm
Poser
Looks like a later model head but yes. Thanks!
PostPosted: Mon May 25, 2009 9:43 am
Poser
So why are they there? Can I grind them down?
PostPosted: Mon May 25, 2009 10:00 am
A/C compressor supports bolt there?
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Mon May 25, 2009 11:17 am
Those are for the fuel rail support brackets and nitrous hardlines.
PostPosted: Mon May 25, 2009 11:35 am
Poser
Sandy you are such the hoser! Take off! :D :D :D
PostPosted: Tue May 26, 2009 6:25 am
Wvenable
Have you SEEN Sandy's NOS setup??? :roll: :roll: :roll:
:lol: :lol: :lol:
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue May 26, 2009 6:28 am
Poser
Nope. But then again it wouldn't be the first time I have looked like the village idiot! :D
PostPosted: Wed May 27, 2009 6:46 am
I have drilled into those for EFI rail mounting and did hit water without going too deep. Be careful.
Why do you want to cut these off?
Users browsing this forum: Google [Bot] and 20 guests
