It is currently Tue Nov 17, 2026 10:59 am
 Post subject: TQ tooth count/diameter
PostPosted: Sun May 31, 2009 5:22 pm
Car Model: Road Runner
Could someone measure the diameter of a /6 torque converter and/or give me a tooth count? I just tried to start my new slant with a converter i had custom made by TCI a little over a year ago, and the starter is hitting the teeth, almost like the converter is a little too big around. this is on a 62 btw, dunno if that matters besides the smaller pilot size.
Thanks.
PostPosted: Sun May 31, 2009 5:55 pm
Makes me wonder if your '62 is really a '61 (or if at some point a '61 trans and starter were swapped in), or if the TCI converter was made with the '60-'61 ring gear. What kind of starter are you trying to use?
PostPosted: Sun May 31, 2009 9:08 pm
Generic 60's mopar coffee-can starter. Same thing that came off the car.
PostPosted: Sun Jun 07, 2009 11:23 pm
There are several different Mopar starters. What exactly do you mean by "coffee can" starter? It matters; please be precise.
PostPosted: Mon Jun 08, 2009 7:47 am
I'll have to take some pictures and part numbers once I get back in town on Thursday. I tried 2 of them, maybe the 3rd would be the charm, lol.
PostPosted: Mon Jun 08, 2009 2:24 pm
How many teeth are in the current ring gear?
The common gear reduction starters use a 122 tooth count.
PostPosted: Tue Jul 21, 2009 6:01 am
I did a tooth count with the help of a friend and a grease pencil. The Ring Gear that they put on the TQ has 148 teeth, so quite a few more than Doc says I need. I called TCI, and they're gonna need me to pull it out so they can ID it and hopefully put something together and get it out to me.
